Does anyone know what kind of capacitors used in BAT VK-40 "6-pack" capacitor upgrade? Is it possible to purchase the correct capacitors and do it myself? Thanks for your help.
BAT has their own name on the capacitors, since most cap companies will add your label to a stock part
for a small charge. You can easily make up something similar with parts of your choice, though.
The response is -3dB at 100Hz into 600R, so they amount to a total of around 3uF.
