Hi all. I was thinking about the above idea the other night. Has anyone there tried putting a shaker transducer right in the centre of a board so that it would be a direct radiator rather than shaking you or the furniture directly? I suppose you would have to be careful of the vibration mode of the board because it would be certain to suffer "board breakup" 😉 as it got ripples in it as it approached it's flexing resonance. Would it be a goer? Would one with a suitable flex-plate attached be suitable as a sort of compression driver for a horn loaded system? Sorry if these are hoplessly ignorant questions.
/Circlotron - stuns the crowd, but not for the right reasons.
I'm pretty new to the Home Audio side of this, but I have worked with Bass Shakers before, and I think with a suitable flex plate you could probably use it as you've mentioned. Though I don't know how good or bad the resulting sound would be. I don't know about the idea with the board though... that's just a little abstract for me to picture, and when I do picture it, all I see is a wobbling board... Either way, I've found experimentation to be the key.
Ask Rolf Harris ....
They were sensitive but prone to peaky/resonant response.
Also, is your description that of the principal of the modern NHT flat panel transducers ?.
Eric.
Remember very old horn speakers that connected to crystal sets that had a telephone earpiece as the transducer - the ones with a coil and polepices arrangement with a stiff steel disk as the moving component ?."Would one with a suitable flex-plate attached be suitable as a sort of compression driver for a horn loaded system? '
Eric.
i use bass shakers, for HT on my couch, and i couldnt imagine them producting much usable output for a horn. they do transfer quite a bit of energy though.
interesting project, keep us informed!
What about installing bass shakers directly behind walls?
shaking your walls could turn out to be fun.. 🙂
i live in an apartment. i am moving in a couple weeks though, to a house. hopefully my roommate (owner) would let me mount them to the floor beams below (that part of the basement is unfinished)
they are really cool. they add a lot to music and HT.
Ilianh said:What about installing bass shakers directly behind walls?
