I wrung up this model, which combines a TH for the bass up to ~130Hz, and a FLH for midbass 130Hz+. my question regards the lower midrange output of the midbass horn. The driver being modeled is an 18 Sound 10NDA610, which has stupid levels of output up to almost ~5kHz (measured). Here in this model, it is in a shallow mult-section, conical FLH. In the model, the output starts to drop a little before 1 kHz. How accurate is that, really? I have this suspicion that it won't drop nearly that early, given it's outrageous midrange output, but that's all it is, a hunch.
Here is the raw driver output measured on Omnimic V2. (red line with AIC engaged, both 2.83V), in a 15L sealed/stuffed box.
