bass delay from subwoofer
So i have recently added some Hertz 6.5" mille pros, they are really good with real good clear crisp sounds, now that ive sorted out the crossovers
What ive noticed is that that the mid bass thump from the 6.5" does not correspond with the subwoofer bass thump
Theres like a minimal 1 or 2ms delay, like the 6.5" Hertz millie pros hits the bass then the subwoofer hits afterwards
You cant notice it with the bass on high volumes but its there
My previous head on my VW had a subwoofer delay option, im currently using a factory head on an Audi A5 B&O set up
I cant change the head because it covers everything else in the car
Any suggestions?
It’s a function of delay indeed, a DSP is the best solution but you could try switching the phase of the subwoofer amplifier to see if that helps.
If it doesn’t try pointing the subwoofer in different directions in the trunk until you find a combination of phase and direction that sounds best.
I find positioning a sub near the rear of the trunk and pointing it away from the driver is a good starting point in most saloons.
thanks would you say that fitting a dsp is an easy job for a amateur? like someone with basic experience? it seems the DSP is connected between the RCA leads and amplifiers?
I got mine from the ‘States as I have family that live out there and visit us a few times a year.
Soundimports.de knock them out for around £150 I think, Buying a Dayton Audio DSP-408 DSP module? | SoundImports - SoundImports
If I wanted another one I’d be tempted just to order from the parts express shop on eBay and pay the import taxes, lots of options.
i see
ive done some research but not finding the info on install
If i got this can i simply connect the input with rca input from my rca tapped from my loc
then connect output rca to my amplifiers?
