as of yet:
i've ordered a 120VA 2x18V 3.33A toroidal, four 10mF 50V capacitors (2 per channel, if necessary i'll get more later), two rectifier bridges, the LM4780 and a pcb for it
i'll be giving it +-25V, that's supposedly 30W per channel at 1%THD, i won't be using more than 10W though and usually it will be at 1W.
now i need a <0.7C/W heatsink and the various thingies (caps, resistors, wires, connectors, fuses, fuseboxes, switches etc)
any comments suggestions or warnings would be most welcome!
Ok so maybe my previous questions were stupid or elementary, i don't know...
now i have an other question
What kind (single/multi strand, other), gauge and type (shielded, unshielded, twisted pair, other) wire should i use for the various connections?
- from mains socket to power switch
- from switch to power transformer
- from transformer to bridge rectifier
- from rectifier to LM4780 PCB
- from pcb to speaker terminals
ok so i completed it
earth connector is connected to middle of symmetrical transformer and also connected to ground, between the smoothing caps :
-Vcc---)|---GND---)|---+Vcc
however i get buzz. i shouldn't be getting this much buzz. the usb is with ferrite core. the signal wire is high quality shielded.
this, (lm4780) amp has lots of buzz.
the other amp did not have the connection between plug earth and middle of transformer. it was DEAD QUIET.
question: what will happen to the lm4780 if i DISconnect the connection between PLUG EARTH ("E") and MIDDLE of TRANSFORMER, but KEEP the connection between middle of transformer and GROUND on PCB?
there is a wire going from the pcb ground to the transformer middle tap (incidentally. the transformer is dead cold ) . there is also a wire going from transformer middle tap to the Earth in the 3wire mains socket. If i disconnect that, the noise is minimized. There is some buzz (not hiss. not thermal noise.) i can still hear if i place my ear about 10cm from the speaker, but i can't hear it from listening position. then again it's not very quiet now, i shall try again at 4am when it is very quiet.
if i connect it, though, i get very audible buzz and in fact i can hear all the noises my computer is making. interference.
I do not directly connect PE to the PSU.
I connect the PE to Chassis. This is the first stage of the Safety bit attended to.
I connect the Main Audio Ground, or just as effectively, the PSU Zero Volts to Chassis. This Chassis connection can be many tens of centimetres from the other Chassis connection. They do not need to be coincident, not even near each other.
I could just as easliy connect the Speaker Return terminal to Chassis. That would be a good connection that can carry mains fault current to PE.
I can see two twisted pairs away to the right. I think these are inputs.
I see a double insulated set going from terminal strip to black square panel and then to PCB. I think these are the 3power wires.
The white pair from PCB look like speaker output.
What is the little orange wire from PCB to speaker terminals?
I don't have a clue where the Main Audio Ground is.
- Chip Amps
- Basic LM4780 amp
