Bang & Olufsen BeoLab 5 SPL curve
Hi! Welcome to the forum.
The Beolab 5 includes four active speaker units, each with its own amplifier - high-range, mid-range, higher bass and deep bass.
There could be a high-range amplifier fault, but unlikely to be present on both stereo speakers.
Let's see what other users have to say.
With the cliff at ~6kHz the graph certainly looks like either the two 18mm tweeters are blown, the two high frequency ICE amplifier modules are not functioning, or the connections into or out of the high frequency amplifiers or tweeters have come apart. They would sound like they don't have any 'air'.
at normal listening level, there is less than one watt (yes 1 watt) going to the total speaker
at party levels, this may be few tens or hundreds watts
but tweeter receives very little due to normal content in treble in music is low
ESP - Frequency, Amplitude and dB
unless someone goes nuts
but, as I said before, wouldn't you know already by listening that tweeters are blown?
You were getting further than this?
(If I can reach it I'll fix it)
