Is it possible adding ultra linear feed-back on the schematics mentioned above?
Just a thought.
There are some mistakes on that schematic.
C21 is going from the center tap on the OPT primary straight to ground. Actually, that's where the B+ supply should be connected. Usually it would be about 450V there (might be different, that's just a guesstimate).
U1, the LM317H, is set to limit current draw to 2.5mA (0.0025 A). That pair of KT88's probably should be allowed to draw around 130mA (ballpark guesstimate). Also, without some kind of protection from overvoltage at turn on, an LM317H is likely to blow up if used that way. The voltage at the KT88 cathodes is likely to be about 45V, which is right up there at the upper limit of the allowable voltage through the LM317H. Maybe a TL783 would work better there (125V max volts). Or use a high wattage resistor there until you have everything working. Maybe 330 ohms, 15 watt wirewound. Experiment with current sinks and all that later.
On the KT88's, R9 and R10 should connect to pin 5 (the control grids). The screen taps from the OPT primary should connect to pin 4 on the KT88's (the screen grids).
I think you want to decouple R20 (2.31k) with a capacitor to ground.
R21 and R22 are 20k ohms, which are going to be much too heavy of a load on your 6SL7 tube. Those should be 100k or so. Then you might want to increase the value of R7 and R8 to 470k, if you can get away with it (ideally 10X the output impedance of V1).
V1 (the 6SL7) might not swing enough volts to drive both the KT88's and the global feedback loop to full output.
Anyway, I hope that helps.
