Balanced Preamp Advice
I built a Chassis that has an Aleph J in it right now but I built it with the idea that I would change out various amplifiers and I want to build a preamp to provide multiple inputs and volume control. Ideally, I would like to be able to bring both balanced and RCA inputs into it and provide a balance out to the amplifier. I have a DAC with a balanced output, a phono pre-amp with RCA, and CD with RCA. I was thinking of building a Balanced Output Son of Zen Pre (BOSOZ) amp and I hope to design a board for input control and maybe individual attenuation on it for each input if needed to get volume matching. If I get fancy I would design it to be selectable for XLR output to the Aleph or RCA output to my Tube amp or whatever. I don't think I need much gain but it seems nice to have some as an option. I have an FE 2022 connected which gives me 10 dB right now and I haven't needed more.
I would also need something for the output side for volume control. I was thinking of a relay-controlled step attenuator board for volume (does anyone have a design or PCB?) I don't need much gain in for the amps I have but it seems nice to have for the future. I like the BOSOZ because I have about 1/2 to 2/3s of the components and it seems simple.
My question is this a good solution or are there better options I should consider? Is the BOSOZ a good-sounding pre-amp? (seems like a silly question since Papa designed it)
Thanks, Is this the same as the BA-3 from the DIY Audio store? I don't have the JFETs and MOSFETs which I think are hard to source. I had boards made for the BOZOS and I have the parts. (Assembly starting this week). If I could get parts for the BA-3 and it is a better preamp I could tweak the power supply and change it out in the future.
Member rhthatcher (great guy) offered the Fairchild mosfets at some point. Perhaps you can check with him.
If you can't find the Fairchild or Toshiba mosfets I would consider just going with the standard IRF510/IRF9510 or IRF610/IRF9610 parts.
Edit: Just found Randy's sales thread: https://www.diyaudio.com/community/...nd-irfp240-mosfets.365386/page-3#post-7646798
It looks like he doesn't have the Fairchild FPQ3P20 anymore. However, he still has some NOS Harris / Fairchild SFP9610. These are good parts and you can just pair them up with regular IRF610.
I have the BOSOZ built except for installing the MOSFETS. I've never installed one where you want electrical contact to the board via the TO-220 tab however this board is designed with the FETs laying flat and a heat sink with screw attaching the drain to the board. I assume that I would still put thermal grease between the FET and the heat sink and electrical contact would be made through the screw on the bottom of the board and the top of the tab on the TO-220. (There is no trace connecting the middle pin of the FET).
