Balanced jfet buffer for Vout DAC?
I'd like to make a simple balanced buffer using jfets for my CS4397 Dac, which is voltage out. (I've just made a jfet RIAA stage, hence enthusiasm for jfets.) :up:
I've done a lot of searching but the circuits I have found all have gain, which I don't need.
Can anyone please point me in the direction of a suitable published schematic, or give me some ideas on how to create, say, a balanced source follower?
Thanks. I was aware of Borbely but your post encouraged me to take a closer look. His buffer would certainly do the job, but I'm still hoping to find something a little simpler and cheaper, particularly now that £1=1Euro! :xeye:
go to Papa's B1 thread and look for version with J310 ( in last few pages) ;
make 4 channel version , two channels will give you balanced (4 for stereo)
you can't make it cheaper and simpler ;
be sure to use decent supply
edit:
here it is :
http://www.diyaudio.com/forums/showthread.php?postid=1681957#post1681957
Hi there,
I am a newbee, so please bear with me, and my perhaps stupid questions :clown: .... I have a few questions in the same line:
I'd like to build a discrete output stage without coupling caps for a DAC which has a DC component (2.5V).
Could this buffer be used? If not, do you know of a simple design that could do it?
Have a nice day.
