Hi! I have built a GG preamp and quite like the character. I am planing to build a balanced version.
I wonder if I add a long tail phase splitter stage
http://wiki.diyzone.net/Image:OTL0630-1.jpg
before the grounded grid would help to increase the common mode rejection ratio of the system?
GG
A balanced version would more look like two SRPP´s working on a tail resistor or current source.
your schematic looks more like a Balanced Audio Technology.
Reinhard
Reinhard
Balanced JJ
Have understand your plan. Why so complicated?
To have a balanced GG you only need one more triode per channel, if you like add your penthode CCS.
Reinhard
Reinhard
Becasue I want to introduce common mod rejection into the system to get the benefit of balanced input
GG Balanced
You will use the gg amp as a buffer, no common mode rejektion there.
As I told you before, use two Srpp stages on a CCS, ready.
Reinhard
Reinhard
