Hello.
I have been playing with a B1-buffer preamp.
I would like to make the B1 balanced, so that i can keep my poweramps, close to spk. !
My quistion is, if the attached picture (Drawn by peter Daniel) will work for output at B1, giving a Balanced B1 ?
Also i would like to keep my RCA's out, for e.g. subwoofer plate-amp. How is this done proberly ?
Jesper.
EDIT : You can see post with big picture Here : http://www.diyaudio.com/forums/audi...kit-building-instructions-43.html#post1712724
Jesper.
select a transformer suitable for output duty.
At the input of the receiver a transformer suitable for input duty must be used.
I only have input transformers.
I have tested a quasi balanced output stage circuit from Jensen transformers App Notes using only 3 extra passive components to convert the single ended output to balanced impedance output. It works and costs almost nothing.
