Bal. In/Out Buffer with H2.
In my PA set up, I use a Presonus Digital Mixer. I find that the mix can sound very sharp and metallic compared to my analogue Soundcraft, for instance. However, the versatility of the digital mixer is addictive.
I was thinking that adding a balanced input/ouput buffer, capable of handling about 15 volts input/output without clipping and being able to arbitrarily set the amount of H2 would produce warmer sound in the final mix.
Any of the Pass designs which can be easily adapted for this application?
Thanks,
Thanks Itsmee for the pointer. However, I am looking for Line Level application and not a power amp. As of now, the front end of the BA-3 (balanced version) looks like the best bet, but I am not sure if it will handle 15 volts input/ouput, even if adjusted for unity gain??
Another candidate might be the BoSOZ! Any more pointers? Thanks.
Thanks Zen Mod; very good suggestion. With the F4 Front End, it is possible to feed an unbalanced signal and derive a balanced signal at the output. (Although I prefer to have the input balanced, as well). Someone will say double up the circuit, I know. However, will the F4 Front End have a low enough output impedance? And is there someway of incorporating an adjustable H2 pot, as in the BA-3 Front End?
Since my 'Toshiba' (313 & 2013) supply from UTsource turned out to be fakes, is it possible to build the BA-3 Front End with IRF output devices, set the gain to unity and get a good amount of H2 to blunt the 'metalic' sound coming from the Presonus Digital Mixer?
Thanks.
you're asking too much from simple approach ;
Thanks.
that's the way to go .
use Papa's balanced BA3 FE schm
