so i have a 1.5 way speaker with a alpair 10p. My thoughts are that if i choose a narrow enclosure then the BSC compensation would be at a higher frequency and there would be a potential lobing between the 2x 10p. At a wider enclosure the BSC would be lower and there would be less potential for lobing between the 2 drivers.
So should i really be concerned about lobing between fullrange drivers operated as a 1.5 way?
Is there an ideal baffle width?
Thank you for any input.
