About 400 Hz. I assume XO slope is also important. I’d think that a steep slope for the woofers would limit issues, but my research mostly points to the opposite being the case.
Nearly every answer to the question of XO point of side firing woofer says under 200 Hz, with many people saying as low as 80. I’m postulating that it doesn’t need to be nearly that low, but I don’t know for sure. Can you explain why you say under 450-500? Pure Omni behavior probably ends around 200 Hz.
Some simulation help understand directivity behavior and why lower is 'better' in this case
https://www.diyaudio.com/community/threads/tachi-coaxial-point-source-bem-modelling.386711/
That said following Dave's design and Fluid's simul i experimented with principle and i second Dave's comment about force cancellation: quiet box/cabinet is very nice to have especially when it work even with very simple design ( no need for thick or heavy cabinet wall).
If you can limit to below 150hz it's even better ime.
Normally for a three way I choose based on baffle step unless mid distortion is an issue, but in this case, as you say, dispersion of the woofers is the deciding factor. Unfortunately, I think that mid distortion may indeed be an issue. I’ll need to take new measurements with the rears closed and see. The ND105’s only model to about 100 dB or so, so maybe I can push them down closer to resonance.Normally you'd try to identify those problems. Assuming you've also chosen the crossover frequency for some reason, that defines the steepness needed. Otherwise we're all guessing.
It's typically preferable to use the most shallow slope that ticks all the boxes, but no shallower.
In this case of course, your main concern is the radiation of the multiple drivers and also the matching of the upper and lower ranges. Otherwise the 400Hz region give or take is quite an easy region for woofers and mids, eg no breakup or lower resonance to navigate around.
Some of this is only going to become obvious if you take measurements at different points around the speaker.
Otherwise if both ways have a range where they disperse the same, it shouldn’t matter where the cross is with regard to the baffle step.
Thanks for that. A lot of helpful info in that thread that I hadn’t seen.Some simulation help understand directivity behavior and why lower is 'better' in this case
I understand why lower is better from a directivity standpoint, but I wonder how much it maters in practice considering room effects and our aural processing in those regions.
What do you mean both ways?Otherwise if both ways have a range where they disperse the same, it shouldn’t matter where the cross is with regard to the baffle step.
Nothing compares to first hand experience: prototype a box, make your own observation and report here. 😉
All i can say relative to 'holes' in power transfer ( non constant directivity pattern) is i'm sensitive to it. If schroeder freq of your room is high enough it might not matter to you but only you could tell.
Experiment/prototype with dirt cheap drivers. Wood for box might cost more than a pair of Visaton or Grs drivers. And no need for ply or mdf as you'll have force cancelation at play.
Indeed. I don’t have the woofers and PR’s yet. The point of this thread for me was to see if it made sense to buy them or figure something else out. It sounds like I may end up with a final sensitivity of 88-89 dB with near wall placement which is more than I hoped for honestly.Nothing compares to first hand experience: prototype a box, make your own observation and report here. 😉
Besides that, I get force cancelation, anechoic f3 around 50Hz, Sd of just 102cm plus 4 PR per side and max output of 100-102dB. All in about 12 total liters. Would you spend the $180 for those things?
In a 3-way speaker the bass radiator position(s) and baffle/box dimensions are practically irrelevant.
Some mild changes (in anechoic environment and simulations) start happening above 200Hz, more relevant above 400Hz (with normal size baffles).
In-room boundary reinfocement and room modes are much more difficult to handle below 400Hz. Typical home listening rooms and non-nearfield listening have Schröder limit around 400Hz, below which we cannot localize sound source. Even the so called floor bounce around 200Hz is quite difficult to hear, but a measurement mic can show drastic dip.
So, the answer to OP question is - no effect. Many very well designed 3-way speakers use single or more down- , side- or backside woofers only ( D&D 8c, Kii-3, Gradient, Genelec)
With dsp the backside woofer of bipole can be delayed to create cardioid or dipole pattern in two octaves (eg. Gradient W371A and many diy speakers)
- Baffle Step losses for dual opposed woofers
