http://zaphaudio.com/audio-speaker12.html
In this design, Mr Krutke says he has about 4.5dB of BSC on the woofer. But all he has in the woofer crossover is the inductor (1st order low-pass) and the LC notch filter (for the 8KHz breakup node).
I'm getting a tad confused
Khron,
The woofer driver is a complex impedance and judicious design with a minimal number of components can still yield the desired BSC curve. Take a look at the graph labeled "woofer filter effect." This shows the actual drive to the woofer and the shelving effect between 200-2000Hz that John was targeting.
You'll see this kind of thing a lot with well-designed crossover networks......the actual topology might not look "generic" (or what you'd expect) but it still accomplishes the goal.
Davey.
Davey.
