Hi, no problem. Yes, petals would be best, symmetry is important. I wonder how far one could go with the petals....... something based on fractals perhaps? 🙂
I once managed to iteratively "saw" out a perfect BUT2 highpass-behavior within +- 0.5dB with a open baffle, starting from an asymmetric logarithmic snailhouse contour. Along with a complementary electric BUT2 this provided a neat LR4 behavior. No kidding, it worked.I wonder if anyone has tried somethings similar for OB, a bit simpler than flower petals 😱🙂
1. But it only worked straightly measured aligned with the driver axis.
2. And any asymmetric design will completely ruin constant directivity. So you better avoid linear snailhouse contours over 360° as in the example shown in this thread.
I don’t think the shape (looking straight on-axis) will have much of an impact on the sound quality. For the cleanest sound the baffle needs to carefully transition the wavefront away from the driver. This improves the off-axis performance since edge diffraction isn’t causing artifacts due to stored energy. This shows clearly in a spectral burst decal plot or impulse response measurement.
Also, Olsen’s graphs were hand drawn based on guessing. I do not agree with some of them based on my own experience.
"carefully transistion" - Have you determined a specific baffle profile that is best? Pic? thanks!
the careful transmission works indeed good. Difficult to measure, at least for me, didn´t succeed. But to my ears, it sounds better than any other baffle I tried (quite a few...), cleaner, no artifacts, better 3-D-illusion. Of course, this is very subjective.
The shape has no special formula or determination - just a smooth curve from the membranes exit angle to the very large roundover.
All the best
Mattes
All the best
Mattes
Petal shapes work well, but are difficult to make. A ball or dome shape is pretty good at at preventing diffractions too. See the old B&W Nautilus and their modern tweeters. Designer or those was Laurence Dickie who is now designing Vivid Audio speakers.
I thought maybe JC had some measurements to support a best overall shape.
Yes, quantifying the audible effect is difficult.
I have made spherical tweeter pods. Felt is installed around the front and flat on the tweeter faceplate. Fabulous sound.
I owned N801 for 2 years and had to unload them. They are extremely open but have several major issues that make them hard to live with. I believe the N tweeter holder is a bad design as there is no baffle for the dome.
Its nice to see creative ideas for dealing with baffle reflections. I like the style of this speaker that has diffusion machined into the baffle..
- Baffle Shape for Smooth Frequency Response
