I have a hybrid Bada ph12 headphone amp with blown MOSFET, which I want to rebuil/mod. I don't want to deal with MOSFET any more. I am going to rebuilt it as all tubes.
The ph12 has three 6SN7 mounte on PCB. B+ power supply is 230v. Heater are from 3 7806 regulators.
I want to re-use as much as possible what is on the PCB. Any suggestions?
OK, I did a quick test today to connect my HT600 headphone dirctly to the 2.2uf cathode follower output capacitor, and I got loud enough volume - about 11:00 o'clock for normal listening.
So if I replace the 2.2uf CF output cap with a larger one, it should be OK for my high impedence headphone.
To get more amp to headphone. I am thinking to put a small output transformer between the CF and headphone. Anyone has a schematic for a parafeed tranny?
If you want to increase output power with 100% tubes, two ways can be studied:
The first solution: add grid coupling capacitor betweem u7 and u8, convert ub8 into a commun-cathod amplifier, add a transformer in the anode to adapt any headphone impedance.
The second solution: don't touch the three present tubes, just add one extra tube as last stage amplifer with transformer. The impedance of the transformer will be defined by the added tube.
I have a Bada PH12, which I find with a few mods to be excellant, however as I will be moving to somewhere that I won´t have neighbours to molest with my sound system, a h/amp is not something i will require in the future, so this is what I propose to do - turn it into a power amp.
My only experience up to now is with all valve amps, so what I am proposing maybe a non-starter.
As I understand it - the output of the mosfets (rated at 125W each) are dictated by the paralleled resistors in front of them.
These presently total 200 Ohms per side - if I want to have an output of 20-25W per channel what value do I need to change these resistors to?
I also intend to use Welwyn W23/9W wirewounds so they will total 36W per channel. I will fix PC coolers to the aluminium top plate, to which the mosfets are already screwed and as I already use a Papst fan for cooling, which is very effective, I forsee no problems there apart from fitting speaker binding posts - what other changes do I need to make.
I also intend to use some exotic caps, which will later be used in the Moskido that I shall build. This project I think is a good way for me to get to understand hybrid amps.
Looking forward to answers as if the Bada sounds as good as a power amp as it does as a h/amp then it will mean no more all valve amps for me.
