😱 These jj tubes never have a good sound. At least choose Nos type tubes for drivers and v amp in first stage.Repair set has arrived.
Oh, I didn't even think about that. Yes, the tubes are going to greatly affect the sound. I think the new Genelex 12AX7 is a good-sounding tube. And the Gold Lion KT88 is probably the best new version of that tube. Especially if you are trying to squeeze 100 watts out of a pair! I find the Russian-made tubes generally sound much better than the Chinese.
🙄😱 These jj tubes never have a good sound. At least choose Nos type tubes for drivers and v amp in first stage.
If the amp sounds bad i would start with some measurments to find out what shortcomings there is. Speculation
without data is just speculation
No measurement can clearly and quickly show the reason for the bad sound of a tube amplifier. It can only show the problem like low power.....
I have in stash oscillating Audio Research SP-9 MKll, what do you think about this preamp? Is it worth to repair or trash it? 6922 I have replaced, but it changed nothing, so I think it one or several FETs.Typically, a Williamson amplifier will have low sensitivity and require a healthy drive voltage. My original Williamson-style monoblocks do. There's also good bit of Miller capacitance at the input. I could also be that the amps are very revealing. ;-) They were certainly well-regarded back in the day.
I use an Aikido-style 6SN7 preamp with mine and it's a wonderful match--lots of voltage output and a very linear, low-distortion signal. Using my DAC as a source isn't nearly as satisfactory.
IMO any decent 6SN7 preamp, like an Icon or Cary, would be a good match for a Williamson. Also good would be a triode 6V6 preamp. You definitely want active gain. I personally have a preference for octal preamps.
If you read the thread, you found out why amp was sounding bad. After measurements (not all of them is here), repair and adjustments amp sounds quite good.If the amp sounds bad i would start with some measurments to find out what shortcomings there is. Speculation
And finally all caps are arrived, this might help to improve the sound too.
I have not read the full thread but was amazed by all advices that seemed to be pure rubbish.
An amp that sounds bad has faults that decent measurment will catch, and with them as base fault
diagnosing and correction ought to be a straight forward thing.
I understand that you have measured and corrected the amp, which i obviously missed in my fast reading, sorry and congrats to a successful repair.
I was too, thought here I can find someone, who have had this amps and knows something about them.I have not read the full thread but was amazed by all advices that seemed to be pure rubbish.
I know this, but earlier have not much time to properly diagnose the amps. And then thought they are ok, but sounding rubbish.An amp that sounds bad has faults that decent measurment will catch, and with them as base fault
Thank you very much!I understand that you have measured and corrected the amp, which i obviously missed in my fast reading, sorry and congrats to a successful repair.
It's been eons since I heard ARC equipment but the SP-9 is highly regarded and would probably serve very well here. I personally would be lost in repairing a preamp with SS components. ;-) If you can find a way to do it it would be worth it, I'm sure.
Have you ever DIY'd your own components?
Thanks, need to find time and figure out wich FETs are bad. The problem with FETs is that, they're only marked with color not the type.It's been eons since I heard ARC equipment but the SP-9 is highly regarded and would probably serve very well here. I personally would be lost in repairing a preamp with SS components. ;-) If you can find a way to do it it would be worth it, I'm sure.
Many of them. But now I have not much time to design something from scratch.Have you ever DIY'd your own components?
Well, it doesn't need to be from scratch. There are a lot of good preamp designs out there. The Aikido is not difficult, there are easily-obtained PCBs to build one here on the forum.
Sure.
Be sure you use the final version. They work nicely, no ground loops!
G'day Guys,
I've been working through this one for a while now and I have nailed down enough of the design details to do a board layout.
Firstly a bit of background as this is not my first rodeo with the Aikido.
My first was a Tubes4hifi.com SP14 kit which I have absolutely loved the sound of since it first fired up something like a decade ago.
http://www.tubes4hifi.com/SP14.htm
I've also built one using Broskie's 12vac Aikido pcb.
New Aikido 12Vac PCB and part kits
I built the 18vac version using 12AU7 tubes. This is testing in my system. It's an amazingly elegant solution...
- Sadface
- Forum: Tubes / Valves
Here is the thread for the Aikido boards by @Sadface . Gerbers and documentation in post #20.
G'day Guys,
- Sadface
Thank you guys. Must only find time to make a decent enclosure.Here is the thread for the Aikido boards by @Sadface . Gerbers and documentation in post #20.
- Tubes / Valves
- Bad sounding Grant G100 AMS KT88 Amp
