Bad pop/cracking sound when powering on
All outputs look like they are cut off but I think this is original. These BD's have pretty short legs making it impossible to bend them and reach the solderside.
Complement of output transistors BD249 is BD250, or for TIP36 that would be TIP35. Both could be original, but normally a manufacturer would stick to one of the pairs. That's all I can see. 🙂
I wouldn't worry about these output transistors for now but focus on the crackling channel.
Hugo
Looking at photos of other genesis monoblocks online the transistors are all the same as mine ( soldered legs ) so yes I think you are correct in that the manufacturers did this to extend the legs .
The left mono is identical too .
Yes, that's not how it should be done. You can see that the metal has only made contact on the sides.
Make sure both surfaces are as clean and smooth as possible, especially around the drilled holes.
I would even drill a third hole in the center, somewhere between two transistors, to fit a third screw, if you have the tools.
I see and agree with what you’re saying trouble is the fins of the heatsink are bang in the middle which as an alternative would mean 2 screws either side of the fins which then means 4 screws ( top and bottom) so probably a cost cutting exercise.
I’m fully aware that the subject of replacing capacitors draws many a heated discussion ( surely this repair/result proves it ) but should I now replace the power supply caps too ? Though I must say that in my humble experience it’s usually the little caps that go bad .
