Bad clock after NOS on CDP-337ESD
Hello Mike!
I do not want to make 337ESD as a NOS player, just would like to have a better clock generator for it. Can you suggest me what kind of clock should I get?
I don't find any clock at 16MHz, like the original crystal.
Hi: Congratulations! You have a beautiful machine!
Try a Tentlabs clock and power supply upgrade:
http://www.tentlabs.com/Components/cdupgrade/xo2xo3/index.html
And go for the other mods described here: capacitors, I/V resistors and in the signal pass, diodes, power regulators. For op-amps BB2134 is my suggestion.
I have the schematics. If you need it please ask for.
And enjoy the robust, punchy, dynamic and detailed sound of your CDP!
Tentlabs XO2.2 arrived today.
Can you help me how to wire it exactly? Should I remove all resistors and capacitors around the original crystal from the CD player or only the caps?
Do I have to connect the tentlab GND to the CD player GND somewhere?
Update: I made it work. I removed only the capacitors and the crystal. I decided to fix the tentlabs panel under the Sony PCB since there is plenty of room. Right under the CXD1125 IC so the cable can be as short as 2cm.
