Back panel for a Dynaco PAT-5 preamp
I need to make a back panel for my Dynaco PAT-5 preamp that will accommodate 14 sets of Neutrik Stacked jacks.
I am attempting to make my preamp balanced in & out. How can I get a steel panel made and drilled for this?
You could cut out most of the back panel and bolt on a flat rectangular plate with all the holes needed.
That would be much less expensive. A place like this could make a laser cut panel cheaply.
Laser-cut metal parts Shipped Fast | Instant Quotes
Thanks! That's quite a good idea!
I've done it, just use a thick enough metal so it's good and rigid when installed. Maybe the same or slightly
thicker stock than the panel material itself. For uses where less strength is needed, you can make a pcb
for the connectors that bolts right into the rectangular opening that you cut in the panel. This is an easy way
to upgrade the original marginal Dynaco connectors.
You can use something like PowerPoint and "draw" a rear panel on thick paper, cut out the holes for I/O, and then sandwich it between the metal rear panel and a thin polycarbonate cover. I've done this and it looks very nice.
