Hi
I am thinking about making a pair of Back Loaded Type Horns using Fostex 4 inch FE 103E Single Drivers.
Fostex provide a comprehensive design PDF
http://www.madisound.com/catalog/PDF/fostexdrivers/fe103erev.pdf
I was wondering if anybody had built this set up. As the manufactures have supplied the design I am hoping it will be fairly foolproof.
The one think that I don’t understand is the use of MDF steps rather than laminated curves on the Horn Mouth. Is this just to simplify construction or is there some sound audio logic I fail to understand going on here? Would not these step set up standing waves? I am very happy to take the mid point and substitute two curves to form the Horn Mouth.
Any feedback would be gratefully appreciated.
Best Wishes
dh
Best Wishes
dh
I believe the steps help break up higher frequencies so you only get lower frequencies out of the horn mouth. Although I have not built any of the Fostex-supplied box plans, I have seen mixed reviews of them on this site.
There are some other designs for the FE103E on this site if you do some searching. One in particular is the Buschhorn MKII.
http://homepage.mac.com/tlinespeakers/FAL/box-plans/buschhorn-Mk2.gif
Hi
Not to discourgae your quest but,
1st. We have built this horn. It is not very good.
2nd. Each step in this manifold horn, and each square bend acts as a low pass filter. Curves would mean HF getting out the mouth, something you don't want to.
3rd. If you build this out of MDF it will be even worse than it is when properly made with the specified plywood.
Do you have the FE103s already or are you just looking to do a small horn? The FE103 is a nice driver, but not best suited to a horn, but there are some that work way better than the Fostex. The B-Horn Chuler mentions, and probably the Frugel-Horn with appropriate tuning of the air cavity.
dave
dave
Did I miss it, or has no-one mentioned that of the 2 Buschorns, the MKI is probably a better sounding design for this driver, or the FE126E for that matter?
I've built at least one pair of all 4 designs ( BH MKI & II, Fostex's "hybrid", and many pairs of the Frugels), and listened to them extensively in a couple of different systems and rooms, so this is subjectively biased of course, but not idle conjecture.
Note that the B1 that Chris mentions is a version scaled to fit a 4" driver, and that all of our trials were with FE126eN (better suited to horns than FE103)
The plans for this are on the very last page of the Frugel-Horn plans.
dave
dave
Thanks for the Links -Whats wrong with 15 mm MDF ?
Thanks for the advice. I will look at the links you all surgested.
Sadly 15 mm Ply is very hard to find in the UK. So What so wrong with MDF ?
I have always used it for speaker projects. It seem likethe perfect 'dead' material. 15 mm MDF is easy to purchase were I live.
Best Wishes
dh
Best Wishes
dh
If your based in Scotalnd (just a guess from your chosen country flag) you might want to check out these guys Rembrand Timber Limited - Scotland's largest independent timber merchant they stock 15mm birch ply. Elsewhere in the UK you could try Avon Plywood or even a local builders merchants, that's where I source my ply from.
Ewan
Ewan
Thanks for the Rembrant timber Link. I normlally use Thornbridge Sawmills who told me they could not supply that product.
dh
dh
Re MDF, its basic problems are high density and lack of stiffness, which at the kind of thicknessess usually used (1/2in - 3/4in) usually puts panel resonance slap-bang in the middle of the bandwidth the cabinet is operating over. For e.g., to equal the stiffness of 3/4in BB ply, you would need about 1 1/4in of MDF (stiffness in a material increases at the cube of thickness), and you still have (an even worse) issue WRT high mass.
For once, I'm going to disagree with Dave WRT the 103 not being ideal for BLHs. From my POV, it's no more or less so than, say, the very popular, slightly larger FE126E. Mass corner is acceptably low, & with its miniscule linear travel & small cone area (and more controversially, its very high theoretical acceleration factor of over 2100 m/s^2 per ampere) if you want to run it sans LF support then a decent BLH is about the only option you have if you want to keep distortion within vaguely reasonable levels.
I do concur that Fostex's published design for it isn't great though. There's nothing wrong with manifold horns, but that one isn't a particularly distinguished example sadly.
I defer to Scott (since his key involvement in any horn work i do -- the usual situation is Scott doing the horn, me doing the drawings and suggesting detail improvements)... my comment was based more on the fact that Scott & i have never done a horn specifically for the FE103.
Be nice to see someone verify its performance in the Frugel-horn
dave
I strongly feel that MDF is a BAD material to build speakers out of... my feeling is that the suitability of MDF for speaker enclosures is a marketing myth so successfully propagated by speaker manufacturers (because it allows speakers to be built more cheaply) that a lot of speaker manufacturers believe it and the idea has become pervasive.
http://www.diyaudio.com/forums/cons...ussion-what-materials-build-speakers-out.html
dave
Hmm. No 103 box. We'll have to do something about that at some point. I've generally tended to overlook it in the past because it's not all that much cheaper than the slightly larger 126. I think the 107 has the same problem with the 127.
The 103 does have a die-hard following though & the midband is rather nice. Be interesting to hear a pair on one of Nelson's current source amps... next time Simon brings his Vampyrs to a meet I'll have to haul along my F2.
Sorry for the OT there...😱
The advantage of the 103 over the 126 is that the 103 doesn't have the big 7k peak...since the 126 mods we highly recommend largely remove that peak, the smaller driver has gotten little consideration.
dave
dave
- Full Range
- Back Loaded Type Horns using Fostex 4 inch FE 103E Single Drivers.
