Babelfish JFET with UJN1208K
I'm thinking about full JFET Babelfish based on UJN1208K depletion mode output devices. What do you think about it ? I know that bias circuit need to be changed. Maybe new external one or feed R22 from negative rail with some changes ?
1. always post reference schematic , meaning one , from which you're referring parts designation
2. best if you introduce third PSU rail ( wimpy in current) , being neg to main neg rail
post schematic here , so we can proceed further , speaking in same terms
(later tonight; in a meantime , search for EUVL's proposal how to edit Aleph J-ish circuit , to accommodate LU JFet outputs ; trick with lower one biasing is what is important to you)
wrong , from many reasons
did you read what I linked in post #3
catch is in "depletion mode device" , meaning that for proper biasing UJN demands negative voltage at gate , ref. to source
also , referencing biasing voltage for upper UJN , to negative rail - is wrong from many reasons
it needs to be referenced to something in between ..... either output or gnd (matter of choice and further rethinking of output stage principle)
now - you can replace entire LM337 shebang with same combo as in F6 :resistor plus zenner across pot across cap;
just wire resistor to neg rail , instead of positive
proceed with changes in input JFet drain , see (again) what's linked in post #3 , to arrange proper biasing of lower UJN
and ... considering that we are really starting from Aleph circuit , maybe best combo should be to transfer to UJN in lower half , and to transfer to ACA -like upper half , with IRFP150 or IRFP240
Pa is lately using that approach - sorta Mi-Follower , instead of earlier Aleph CCS ...... with goal to have iteration of active CCS , while benign in nature ( not adding too much of own flawor in sound)
that way , you'll still have UJN dominant in entire picture , while lesser complication
few things ......
- you'll need either two J511 in parallel , or something different ...... needing more current there than from JFets drain
-R32,R31 ..... if you leave them , they can be start of making upper UJN as proper Aleph CCS , so time to think how to rearrange upper bias scheme and to introduce resistor from output to gate of that UJN
-delete Q8 and these two resistors ...... due to polarity at lower UJN gate , that's just a mess
