BA-3 Front End, Complimentary output stage, Transformers
I have had these sitting in a drawer for a while. I had the front end functional as a preamp. I scavenged the 10uf caps and the JFETs for another project. I populated the complementary output stage with the intent of building the amp but never got around to it. Now I have other projects that I want to complete.
The transformers are 250va 24v Triad units. They are pretty nice compared to the typical Anteks that I have used. New they are around $110 a piece. My intention was to do a dual mono setup which they would be perfect for. Expect along the lines of 30v-32v rails which should get you around 40-50 watts. 5u case would be nice.
So this includes
-BA-3 Front end mostly populated
-2x BA complimentary output stage populated outside of Mosfets (rhthatcher is a good source for those)
-BA complimentary bias boards populated
-2x Triad 24vac ~10.5 amp transformers
The whole lot is $175 plus shipping.
No interest yet? What if I sweeten the deal with a dual mono CRC cap board and rectifier snubber boards?
The cap board takes 52 mm screw terminal caps which look pretty sweet when installed.
This is a fabulous deal. Someone needs to snap this up, and it can't be me!
Note - Another member also has some BA-1 output and bias boards... Someone could have one super, super nice rig with very little effort with maybe some mixin' and matchin' in their future. Just sayin' 😉
Thanks. This stuff is just sitting around and I already have a few of the push pull dynamic types of amps at the moment.
I saw the BA-1 kit. I am not too knowledgeable on the IRFP040 mosfets but I do think the single ended output board could be interesting. It would be cool if someone had an Aleph amp and the BA-3 single-ended to compare.
