Mine has got Obbligato PIO's and they are """" NICE """ Also using a Salas Shunt Reg.
Those things are HUGE! Scared to imagine how much they cost. Did you make much experiment with the input capacitor types?
Ok. Regarding Obbligatos. I like them (thanx to KatieandDad) but I think very worthwhile alternative is my MBGO 2 caps NOS from Russia.
I might reverse back to them after all...
You can use anything you like as long as you can make it fit. Although the Obligattos are HUGE they did fit.
Dont´t know where I should post in this thread with my problem, so I try here.
As soon as I turn the volume down in my B1, also the high frequencies getting damped.
I have to say that in the first place I installed the transsitors wrong with 180 degree. Now I installed them correct but the problem remains
I am using a PCB which I found here
DIY Audio Projects Forum • Pass B1 buffer clone (be1) with layout - A weekend project.
I installed the transistors wrong with 180 degree. Now I installed them correct but the problem remains
JFETs are symmetrical in construction so should have survived, but thats no guarantee.
Do you have access to an oscilloscope and signal generator to see if you have a bandwidth problem when the signal is attenuated.
- B1 Buffer Preamp
