Changed to old ones. Hum has gone.
Can be the problem in placing them outboard ? Let's say wires pick up hum (they are short though , 4 cm long) from other components ?
Probably just bad caps.
Outboard can be an issue, but in this case it's likely not a big problem.
I used Obliago 10uF PIOs reliable and nice sounding for the output caps and 1.0uF MKPs on the inputs.
Made a new and more compact PCB layout for the B1 (which I already have a couple of versions of).
For details, click the link to my blog 🙂 Comments are very welcome.
/U.
/U.
No, nothing at all. However, if anyone else wants to do a GB of some sort I'd happily share the files.
/U.
/U.
A wonderful idea!
Don't forget to ask Nelson for permission... (although it will likely be no problem)
PIO caps
I finished mine today.
100k stpped attenuator and a cople of HUGE PIO caps.
There wasn't room for a PSU, do I use battery instead.
Nice and open sound, but a bit light on bass, do you think bypass caps could help?
Ciao!
Ciao!
Haha, I remember seeing a picture of a Hiraga amp with a 4U rack for the PSU (had more than 1F supply capacitance) and then the amp boards on two medium-sized heat sinks on the back - this is pretty much the opposite 😀
/U.
/U.
Ciao!
Wow, those caps are huge.
That happens to me when my batteries get low as well...try and charge or replace your batteries.
/U.
You're right!!
hey, you can get nice battery 'box' like the ones used for guitars
Yes, i know, but I spent all my money on caps... 😀
Seriously, I thought it's ok because they're hidden behind the preamp..
- B1 Buffer Preamp
