B1 Buffer Preamp
That's what I thought. But searching "DCB1" doesnt Point the Way? Where do I find the schematic of the dc coupled B1 without Caps? thanks for a hint
Look and see... 😉
Came across the JFET buffer design paper pointed out in the link. Nice and simply. I would like to design that one and compare it with my B1 buffer. But, I am not able to find out the values for the following items -> Cc, RIN, RL. an someone let me know the correct values to be used ?
Best regards,
Bins.
for folks that want to read about design of the jfet single ended buffer, i wanted to share again this article from dennis feucht.
i first saw this circuit in the early 70's (yes, i am an old phart 🙂 ) in some old (even back then) national semiconductor datasheets showing test circuits for some of their parts.
i don't have access to an audio precision (maybe mr. pass can share some data at some point), but you can get pretty good performance from this circuit using some cheaper, easier-to-get jfets like the 2N5484, etc. so, save your 2SKxxx for your phono preamps.
enjoy!
mlloyd1
I built the Pass B1 using the BOM here: Nelson Pass B-1 preamp kit
Using Passdiy's board, JEFTs, Alps 50K pot, ...
I put the board on a MDF and lift it so no direct contacts with the board from the bottom (picture below) and...
The situation is now like this: When I hook it up (Class D amp), I turn the volume to minimum, input switch to the correct input (either 1 or 2), and there will be "Buzz or Hums" from the right channel. When I turn the volume to maximum, "Buzz and Hums" will come out from both channels. If I touch the bottom of the left most resistor right next to the cap, there will be big hum/buzz from the left channel (regardless of whether there is input signal or not).
When music is coming from Input 1 and I set the input switch to "Middle" or "input 2", if I turn the volume all the way to maximum, I can hear the music playing in low volume along with big hum/buzz. I feel like the sound is "leaking". Is that normal aside from the buzz/hum problem?
I added the LED and it is working correctly - it will light up when the power is on.
Any helps are appreciated!!!
After a few experiment, the noise will change if I move the location of the pre-amp. It tends to get smaller if I lift it higher. The Class D amp is on the ground residing in a MDF box.
If I use a different amp (HK 635), the noise will change - smaller in this case.
Am I having EFI or something similar? Would grounding help? How to ground the Pass Preamplifier?
Everyone should give the Lightspeed a try as replacement of the B1's volume pot. It varies from 55R to 30k with a 5.5V supply. I have it connected directly to my amp which already has a buffer so I'm not building a B1. Highly recommended...here's the link to my post at the LS thread- http://www.diyaudio.com/forums/anal...uator-new-passive-preamp-320.html#post2164061
Of course DCB1 builders should try it too...so simple and cheap!
Looks like noise pickup. Check your grounding, put the pcb in a grounded metal box, and keep it away from an unshielded
Class D amp.
Hi guys, here is a picture of my B-1, as you can see it is a "plywood wonder" for now! I am planning on creating a nicer case for it, as well as making it into a balanced version. For now I am just enjoying it, sounds great!
Thank you Mr. Pass:worship:
P.S. if anyone has a leftover B-1 board from the peranders group buy, please e-mail me.
Did I see a grounding wire in the up-right corner of the board?
I am using a MDF box and was thinking how can I ground the PCB. It's picking up noises...
Class D amp.
I did not do any grounding. If I place B1 in a MDF box (don't have any metal box), or wood board, could I use the four corners of the PCB to do grounding?
I saw a guy putting B1 in a cigar box, using four mounting screws lifting the PCB up, place copper tapes on the wood, and put mounting screws on copper tapes. Would that work in my case?
Thx!
