You might double check the orientation of the JFETs. Some actually work backwards and some don't work the same at all backwards
Re: Soldering little bugs
Oh I don't know about the Scotch, depends on whether it will steady your hand more than it blurs your vision. 🙂
I actually manage the purchasing department in a large Electronics manufacturer. We have 3 SMT lines, Genisis, GSM and Panasonic. We use Loctite SMD Adhesive to hold parts in place, but it needs to be ordered over night delivery as it must remain refridgerated until use. If you have a lot of parts to put down the Toaster oven method works with a little practise, but for one offs I still prefer a steady hand and a bit of solder.
Anthony
dcbingaman said:Anthony - I like your suggestion - I've also heard folks use double-sided tape to hold the little devils in place on an SOJ-to-DIP adapter PCB.
In your experience, however, is it better to try this before or after a nice glass of Balvanie Scotch ??
udailey said:In pcb assembly houses they use a little dot of some special red glue. I dont know how special it has to be but a tiny dot of some adhesive on the back of each SMD part, put them in place and let it all dry, then go to work with the iron.
Uriah
Anthony
tooling adhesives for SOIC's
I like the adhesive idea - I was thinking potting compound might work OK also, but I might try either super-glue or "Gorilla Glue" contact cement first. You guys have convinced me that this is doable.
And, Anthony, in my case, the hands steady before the vision goes with good Scotch....but that is only after one. After three, all bets are off. According to my wife, even my other appendages are of little use. I say its age !!
Re: tooling adhesives for SOIC's
My wife is the Scotch aficionado, I am a beer snob, Spitfire Ale, Old Speckeled Hen..... anyway remember the point of the glue is only to tack while you are soldering. Most of the product you mention will ensure a permanent bond and heartache if you have to rework.
Anthony
dcbingaman said:I like the adhesive idea - I was thinking potting compound might work OK also, but I might try either super-glue or "Gorilla Glue" contact cement first. You guys have convinced me that this is doable.
Anthony
Re: silent b1
Glad I read this: I was wondering why when I played with the pots, there was no change in volume.
Duh! Wired things in reverse and no grounds whatsoever!
rob lenk said:one question and one suggestion
check that you have voltage on the board- positive 18 or 24 volts at a transistor to ground- remember this buffer draws very little amps so if the positive volts are there you are probably ok
assuming you didn't burn the transistors soldering them(and from the photos it looks like you did a nice job), the my guess would be the volume pots- wired backwards or shorted out- by pass them with a 25k ohm resistor and, a small prayer if you are of that persuastion-
hope it goes better
rob
Re: Re: tooling adhesives for SOIC's
Gorilla Glue expands while it's hardening. I don't imagine that would work well. Maybe loctite threadlocker blue would work if you can find a way to apply small amounts.
Anthony
Volume....
I paid close attention to the plus/minus when I assembled the B1 but that seems the easiest place to start. There is no "star" ground to the chasis as the board is on nylon standoffs. The RCA input and output "G"rounds are all insulated from the chasis also. All wired connections to the RCA's, Pots, and Toggles are single conductor wire insulated. Wire insulation on all wires is not connected. I do notice that there is distortion after the volume is turned above 50% although volume is extremely low.
I don't understand "backkwards" FET's ???
-BP
-BP
b1-bfny response
Mr BFNY-
lovely reference to the texas instruments facts page-great reading!
I really need to go there more often- they have some great freeware on building sallen-key filters
thank you so much for the input
rob
Mr BFNY-
rob
balanced setup.
Didn't someone earlier do a post about using the traditional B1 schematic in balanced operation by using the out's on these tied to a 1 and 2 of XLR? I can't seem to find such a post. Was I dreaming it?😕
Re: balanced setup.
dunno .....
maybe I did ...... maybe not ;
use one stereo B1 per channel ....... one channel of B1 for pos. leg , other channel of B1 for neg. leg
look in PSM LS thread to see how 4 separated buffers are used for balanced operation .
peace of cake .
Tea-Bag said:Didn't someone earlier do a post about using the traditional B1 schematic in balanced operation by using the out's on these tied to a 1 and 2 of XLR? I can't seem to find such a post. Was I dreaming it?😕
dunno .....
peace of cake .
Some first reflections on B1 ... Remark: I am talking here about "original" Pass B1 design.
I had some thoughts on power supply. The question was how much to invest in it: whether to go with good shunt reg or to use something simpler or even to go with something very simple - that was the first question ..
So together with a friend of mine I put simple power supply of 18 V DC: transformer -> elco -> standard LM317 Reg -> B1. On the input of B1 I have Nichicon Elco of 15 mF, 25V. On the other side I put together simple battery supply made of lot of AA Alcaline 1,5V batteries. The voltage was the same: 18V DC. I installed a switch so that I can easily switch from one supply to another. And I couldn't really hear any difference in sound reproduction.
Then I increased the battery voltage to 23V. And again I couldn't really hear any difference. I know that THD is lower when the voltage is higher but in real life I cannot make difference ... at least not on the system where I was testing (solid middle of the class HiFi system).
These are some experiences that might help somebody. My personal conclusion is that B1 is made as a simple buffer and that it should be kept simple. Maybe some experiments with input and output caps would be interesting (for example with Auricaps) but power supply should be done correctly but there is no real need for some extravaganza ...
http://i277.photobucket.com/albums/kk50/dejan2604/PassB1.jpg
b1-redux
nice comparison-interesting conclusion
thank-you
my thoughts when looking at your pics -are now upgrade the vol pots with the same battery vs simple regulation power supply and see if you can hear a difference.
thanks for your shared experience
rob
thank-you
rob
I've tried Jantzen, Dayton, Sonic Caps, and Claritycaps in my B1, IMO the type of capacitor used can make an substantial difference.
Re: b1-redux
I don't see a pot at all in that pic - is one being used?
-j
-j
Sure, what's your ranking?Face said:I've tried Jantzen, Dayton, Sonic Caps, and Claritycaps in my B1, IMO the type of capacitor used can make an substantial difference.
I am still wondering why paying for quality capacitors when B1 can safely be made without input and output coupling if using symmetric (+/-) supplies. I still use it like that for months now, and the offset is practically null. And no cap always sounds better than any cap.
If I was using B1 for main system, I would use +/- 10V Mosfet shunts, and minimal applicable Shinkoh input and output series resistors (after test in given system for square waves). That is how making it for top performance.
Hi Salas,
Avoiding crossover distortion and "coloring" the sound at our liking?
I've been told that some Tube amps do have capacitors on the signal path...
Anyway, I'll soon make that capacitor-less buffer for my TVC 😎
I hope it is not too neutral...
M
M
Its not cold when capacitor-less, it sounds neutral but soft. Maybe a bit ''gray''. The input and output resistors values and quality as well as the pot seal the tone. +/- 10V is the sweet spot I found for most relaxed sonics.
In tubes the capacitors are more to see because of the vacuum device one way nature, economic and bulk cost of extra PSUs etc. Every time we use better capacitors, they show there too. So it would be better if they weren't needed.
- B1 Buffer Preamp
