B1 and impedance matching?
I am building a B1 and trying to decide where to use it in the audio chain.
Here is what I have:
Krell CD-DSP MkII > Cary SLP70 > EV Dx38 > QSC PLX 1202 for LF + DIY 2A3PP amps for HF > Klipsch Jubilee 2-way speakers.
Krell CD: Output impedance unknown.
Cary SLP: Input 47K ohms; Output: 800 ohms
Ev Dx38: Input: 20K ohms
QSC PLX: Input 6K ohms (unbalanced) and 12K ohms (balanced)
DIY 2A3PP ams: Input impedance unknown.
I removed Cary SLP70 from the chain and inserted a 10K pot. I like the clarity and the detailed sound stage I am getting but there is some loss of air and bass. I was planning to use B1 instead of the 10K volume pot. Is this the best place to insert the B1?
Kudret
Does your EV Dx38 processor have a volume control? If so try:
Krell CD-DSP MkII > EV Dx38 > etc.
This exactly what I did. I used balanced out from CD to balanced in on Dx38.
Yes, Dx38 has 2x10K separate internal pots. I bypassed the internal pots with an external better 10K dual pot. This has improved clarity and the sound stage a lot but there is some loss of bass and air.
Kudret
...but there is some loss of bass and air.
I have no idea what causes that.
I suppose you can now try with the B1 between CD and Dx.
...Dx38 has 2x10K separate internal pots. I bypassed the internal pots with an external better 10K dual pot. This has improved clarity and the sound stage a lot...
That is surely a good thing. I hope your experiments with the B1 make it even better!
