b&w nautilus inspired,
hi, does any boy know any more about this project i.e. what speakers/ volumes are used for each of the chambers, or have links to sight where any one has build a similar look and feel speaker?
http://www.mundohi-fi.com/portal/index.php?module=Pagesetter&func=viewpub&tid=8&pid=8&page=1
blake
blake
The tweeter is the ScanSpeak R2904/7000-00; the mid and bass drivers are in the SEAS Excel magnesium line, but I'm not certain which models - the bass may be the W26FX-001 10" unit.
Too bad they didn't describe their crossover - at least I didn't see that but then I don't speak the language.
This would be a huge and costly project, as the website suggests - if you want the same look you're in for the same kind of work; if you just want the same kind of sound use the same drivers in a conventional cabinet and save yourself a lot of time and some money.
You will still need to design a crossover - read up at
http://www.rjbaudio.com/Audiofiles/FRDtools.html
There are a lot of high end 3-way designs at:
www.humblehomemadehifi.com and
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
