B+ voltage load line question
When a B+ voltage is measured and used to select components to bias your preamp is it with the tube connected or just an open power supply?
I have two B+ voltages derived from two rc filters fed by a bridge rectifier and a smoothing cap. All caps are 47uf. The two resistors are 5K. I used these voltages to design and then constructed my circuit. When I measure the B+ it is about 30 vdc lower. I never took into consideration the drop over the 5K resistor? Or is it just from loading the supply?
So which B+ voltage do I go with when constructing my load line... tubes connected or unloaded power supply?
