B&K CS-117 question
I am hoping someone has a B&K CS-117 laying around so I can find out what type and how many fuses this unit uses.
The manual states 1/2 amp fast blow but has different marking’s on the fuse holder mechanism.
So if someone has one could you please let me if it requires two (which the fuse holder holds) and if they are 120V 1/2 amp fast blow.
I have attached a picture of the only values I see on the holder which does not look correct in way, shape or form.
Thanks, James
Markings on the fuseholder are the maximum the holder can accept safely. Not what the amplifier can take.
And this is a pre-amp. No way it wants a 10A fuse. Manual says 1/2A Slo-Blo. What happens when you try that?
Have not tried it yet (and need to verify if I have any) as I want to verify it is a 120V 1/2 FB.
I know there is no way the marking indicate the type of fuse, just wondering why they are there, as I have never seen a fuse holder state something other than what it uses. It also has places for two fuses, but one is probably a spare fuse holder, which would be easy enough to find out.
Just wanted to see if an owner could let me know what they have.
