Steve D or anyone:
The new Behringer DCX 2496 handles crossovers (your choice of type) up to 3 way, and up to 4th order LR, in the digital mode, for USD $350-440.
It also allows stereo parametric EQ.
Behringer advised me that if used for 3 way crossovers, and both 24 dB/ octave LR,
"you should have approx 17% processing power free. Each EQ band needs approx 3-4% of the DSP power".
They’ve confirmed that this option (24 dB/ octave) would allow each channel _just_ 2 bands of parametric EQ.
(Minimum EQ bandwidth is 1/10 oct).
There may be an upgrade where you can choose the sample rate between 48 and 96 kHz.
48 kHz gives more space on the dsp power.. but they can’t say when or if it will come out.
Does the dbx Driverack PA, or another similar product, when used for 24 dB/ octave, allow more bands of parametric EQ?
