Autotek BTS 7150 BD911 (Zed Audio amp)
Failed PS, and partial channel failure. Output set of TIP35C (2) need to be replaced. Also the BD911 output driver appears like the solder pads overheated slightly, but the component is still working. I'd like to pop that one out of course.
BD911 equivalent if possible? BD911 has about 3A SOA at -32v
NPN TO-220 On hand:
TIP102
MJE15030G
TIP41
2N6488 (2A SOA at -32v)
Will any of these work? I seem to recall seeing TIP102/107 as Drivers in some Zed amp's output stages, but it would seem that 2n6488 might work best data sheet wise equivalent.
Amp is running +-32vDC rail.
Thoughts?
