i want to me use rew autoeq to flatten my system response , i´m not getting as good results with minidsp as i had when my system was passive
Depending your use you must look for:
-Accuracy +-dBs
-Frecuency range
-For professional use or advanced measurements have to be calibrated
If you want go seriuously here you can buy calibrated SPL meter & calibrated mic Cross·Spectrum - Galaxy CM-140 Sound Level Meter
-Accuracy +-dBs
-Frecuency range
Here you can get very good advice about to use REW REW Forum at Home Theater Forum and Systems - HomeTheaterShack.com
thanks , i only want the spl meter because of rew , i´m not worried about spl only about frequency response
but if you want to be sure REW reads will be better to have both devices calibrated: SPL meter & mic.
i never worked with rew before maybe you can give me some hints , i have to find out how to make the mic and spl meter connections too 🙂
You can follows Home Theater Shack REW tutorial:
-YouTube link Room EQ Wizard: REW Room Measurement Tutorial - YouTube
-REW forum REW Forum at Home Theater Forum and Systems - HomeTheaterShack.com
just a quick question (i´ve seen the youtube tutorial) after the mesurements , how does rew interact with minidsp for making the corrections ?
See miniDSP tutorial to know how introduce the EQ, once installed in the mini-DSP you only needs to power the miniDSP & cabling the unit.
REW creates the filters and you only need to put these filters in the miniDSP.
the rew auto eq doesnt work with this plug in i use , i think i will have to mesure and apply eq manualy
yes , rew allows to export a txt file with settings (biquads ?) but my plug in doesnt allow to import the files , i believe i have to manualy insert the biquads
