I am planning to put those drivers each in a box of about 20 x 30 (baffle) x 20 cm (deep) box, (8" x 12" x 8") as a woofer only. That would account to 12 l , a little less than 1/2 cu. ft. I would like to make a cutout port on the shorter side, about 20 x 2.5 cm (8" x 1"), deep as needed, probably about 15 cm (6") as a port.
The midrange-tweeter would be stacked over, in a separate chamber.
Do you think it is feasible? Could you give me some hint how to to simulate it? I am a total beginner in this field.
I do noot need exceptional bass, 80-100 Hz cutoff would do for me.
If the box would be too small, I could put it in communication with the midrange chamber, getting about another 8 L, so a total of 20 L, a little more than 2/3 cu. ft.
