The point is made when one looks at our best efforts in signal processing to analyse even something as specific as speech in noise - it's not 100% successful.
No programs are able to extract & follow a conversation in a noisy room full of different conversations which we can do. This is the so-called "Cocktail Party Effect"
He sells expensive audio electronics so it's not surprising.this is about perception, which is not what you where talking about in PMA's thread, there you kept going on about the validity of abx because of lack of controls and vehemently extorting that people where drawing false conclusions based on results/findings.
seems your already hedging the row with the suggestion that perceptual narrowing and autism are related, not sure how that applies to ABX testing unless your pre saucing this goose to later say all participants are mildly autistic.
I'm probably interpreting what he said in too simplistic a manner: That is, a number of different sound sources, in blue, could have been mixed to produce the same result, in red.
The blue sources are two of the various conversations happening concurrently - what's arriving at the eardrum is the combination of these two sound sources simply mixed (shown in red) as vibrations that move the eardrum, generating nerve impulses.
Those nerve impulses are just a string of electrical signals which correlate to the eardrum's vibration.
Auditory processing's job is to separate out source1 from the rest of this mix of electrical nerve signals so that we can follow the conversation from source1
You're so sure of yourself that you see no possibility that you could be wrong, do you? And with the feverish surety of a zealot you castigate any & all that I say.He sells expensive audio electronics so it's not surprising.
At one level it's simply stating the obvious, take any 10 second sound clip at 44.1KHz and you can decompose it into a sum of two streams of 441,000 numbers (essentially infinite choices) most of them taken individually are just noise/garbage.
does purple kool-aid go with scotchHe sells expensive audio electronics so it's not surprising.
I'm afraid that this is a completely incorrect analogy to what is being said and what's in the video - it has nothing to do with digital audio - it's to do with the makeup of auditory scenes in the real world & the issue auditory perception faces in making a realistic & reasonably accurate internal representation of this auditory scene.At one level it's simply stating the obvious, take any 10 second sound clip at 44.1KHz and you can decompose it into a sum of two streams of 441,000 numbers (essentially infinite choices) most of them taken individually are just noise/garbage.
Yes, his wording threw meAt one level it's simply stating the obvious, take any 10 second sound clip at 44.1KHz and you can decompose it into a sum of two streams of 441,000 numbers (essentially infinite choices) most of them taken individually are just noise/garbage.
I think you're missing his point: "infinite choices"I'm afraid that this is a completely incorrect analogy to what is being said and what's in the video - it has nothing to do with digital audio - it's to do with the makeup of auditory scenes in the real world & the issue auditory perception faces in making a realistic & reasonably accurate internal representation of this auditory scene.
Sorry, given any phenomena that is a linear sum of two others you have no a priori knowledge of anything but the result. It has nothing to do with digital. People hear voices in totally random noise (don't tell me you haven't listened for them).
I'm not missing his point - he is just wrong, I'm afraid. A well-posed problem have the properties that:
- a solution exists,
- the solution is unique,
- the solution's behavior changes continuously with the initial conditions.
An ill-posed problem does NOT have an infinite number of solutions.
When we are talking about perception, there are not infinite possibilities - how fast do you think the brain can process data?
Sorry but I find his post is just confusing matters
But you do have a priori knowledge - knowledge of how sound behaves in the real world & this is used in auditory processing analysis & greatly limits the possible solutions.
Keep in mind that we are talking about perception - a biological process, not a mathematical abstraction
In fact it does have virtually infinite local minima in the mathematical sense. Come on this guy is MIT I know what he means. He starts out with the typical abstraction of this problem and proceeds to show how it's different, as simply a waveform on a scope you can come up with (virtually) infinite choices of two waveforms that add up to the one you have. So move on.
I think you've got what he said **** about faceAn ill-posed problem does NOT have an infinite number of solutions.
Cleared them up for me, isn't language great?Sorry but I find his post is just confusing matters
Anyway, the rest of the talk is hunky dory
This is a joke right? "This guy is from MIT I know what he means"In fact it does have virtually infinite local minima in the mathematical sense. Come on this guy is MIT I know what he means. He starts out with the typical abstraction of this problem and proceeds to show how it's different, as simply a waveform on a scope you can come up with (virtually) infinite choices of two waveforms that add up to the one you have. So move on.
You are simply confusing everything hes says & proving by your posts that you don't understand what is being said
I gave you an example of how we have a priori knowledge about the problem space which you stated we didn't. Josh Mcdermott is a well known researcher in the area & I know what he says - never does he say that there are an infinite number of possible solutions - he goes on to say at 3:00 that assumptions have to be used to solve these problems & we know that "real world sounds have some degree of regularity"
So, again, I'm afraid that you are wrong here so please move on, you're only confusing matters
- Member Areas
- The Lounge
- Auditory Perception in relation to this hobby
