Audison SR1DK resistor value
Power supply cooked up, and the component values are not visible anymore.
Does someone has the values or a photo from the burned components?
R234
R231? (Marking burned)
R250
R251? (Marking burned)
hello can you help me on this amplifier my text and translated via Google the original text is in French the problem is that I replaced the resistors burn the fets and when I plug in the amplifier the red LED lights up for a moment and then the blue flashes with the red do you have any idea about the problem thank you very much
