Hi there guys,
Is there someone who has found an alternative output fet driver transistors for the Audison SR1Dk?
They use 2sb1236a/2sd1857a originally, but those are hard to get.
SR1DK - Audison Monoblock drivers replacement
I've still have to test if I can fit 2SB649A + 2SD669A?
The supply voltage from collector to collector of the drivers seems to be only about 20v (confirm). If so, there should be many drivers that would work.
