I participated in the audiotek saga/misadventure on ebay recently and was left with some 'bags of parts' without assembly instructions.
A few of the kits are so simple that the PCB can be loaded without much help- eg the ATP150 PSU board.
Several members of the forum helped me with links and other info which allowed me to assemble the more complicated boards in my collection.
Thanks to everyone! My apology to anybody I haven't mentioned by name here.
From ibmeris:
http://forum.analogmetric.com/forumdisplay.php?fid=16
most of schematics
From Jean-Paul:
USB/Analog Digital Amp
http://www.diyzone.net/images2/PDABOM1224-1.xls
http://www.diyzone.net/images2/PDASCH1224-1.pdf
IR Volume control
http://www.diyzone.net/images2/VR1127BOM.xls
http://www.diyzone.net/images2/VR1127SCH.pdf
All FET Regulator
http://www.diyzone.net/images2/ALL_FET_REG_SCH.pdf
http://www.diyzone.net/images2/ALL_FET_REG_BOM.xls
Input Selector Switch
http://www.diyzone.net/images2/SW0617SCH-1.pdf
http://www.diyzone.net/images2/SW0617BOM-2.XLS
Angela Amp
http://www.diyzone.net/images2/ANGELA_SCH.pdf
http://www.diyzone.net/images2/ANGELA_BOM.xls
Maple 6SN7 Tube Linestage
http://www.diyzone.net/images2/MAPLE_PRE_SCH.pdf
http://www.diyzone.net/images2/MAPLE_PRE_BOM.xls
5670 Tube buffer
http://www.diyzone.net/images2/TUBESCHFINAL.pdf
http://www.diyzone.net/images2/TBSBOMFINAL.xls
Digital Source selector
http://www.diyzone.net/images2/DS0718SCH-1.pdf
http://www.diyzone.net/images2/DS0718BOM-1.xls
'CUTIE' Mini Regulator
http://www.diyzone.net/images2/MINI0113BOM.xls
http://www.diyzone.net/images2/MINI0113SCH.pdf
Delay Output Module
http://www.diyzone.net/images2/DE0813SCH.pdf
http://www.diyzone.net/images2/DE0813BOM.xls
The speaker protection board schematic is attached.
John
From ibmeris:
most of schematics
From Jean-Paul:
IR Volume control
All FET Regulator
Angela Amp
5670 Tube buffer
Delay Output Module
John
More links from Jean-Paul:
Phase 120
http://www.diyzone.net/images2/PHASE0809SCH.pdf
http://www.diyzone.net/images2/PHASE0809BOM.XLS
LM4765 STEREO AMPLIFIER
http://www.diyzone.net/images2/LM0730SCH-1.pdf
http://www.diyzone.net/images2/LM0730BOM-1.xls
HDAM SA Buffer Module
http://www.diyzone.net/images2/HDAM_BUFFER_SCH.pdf
http://www.diyzone.net/images2/HDAM_BUFFER_BOM.xls
C22 Preamp
http://www.diyzone.net/images2/NEW_C22_SCH.pdf
http://www.diyzone.net/images2/NEW_C22_BOM.xls
Marantz 7 Preamp
http://www.diyzone.net/images2/M7CSCH0822.pdf
http://www.diyzone.net/images2/M7CBOM0822.xls
Citation 12
http://www.diyzone.net/images2/C12BOMMOD.xls
http://www.diyzone.net/images2/C12.pdf
Virgo
http://www.diyzone.net/images2/VIRGO0904-4.jpg
http://www.diyzone.net/images2/VIRGO0904-5.jpg
HEADPHONE PROTECTER
http://www.diyzone.net/images2/IRIS0412SCH-2.pdf
http://www.diyzone.net/images2/IRIS0412BOM-1.xls
TDA1543 DAC
http://www.diyzone.net/images2/TDA0502SCH-1.pdf
http://www.diyzone.net/images2/TDA0502BOM-1.xls
OP PWR SUPPLY
http://www.diyzone.net/diy/power/oppwr.jpg
MOS PWR SUPPLY
http://www.diyzone.net/diy/power/mospwr1.jpg
CR PWR SUPPLY
http://www.diyzone.net/images2/CRBOM0702A.xls
http://www.diyzone.net/images2/CRSCH0702.pdf
Speedo
http://www.diyzone.net/images2/SPEEDO0521-3.jpg
http://www.diyzone.net/images2/SPEEDO0521-2.jpg
http://www.diyzone.net/images2/SPEEDO_BOM.xls
Phase 120
C22 Preamp
Marantz 7 Preamp
Citation 12
Virgo
HEADPHONE PROTECTER
TDA1543 DAC
OP PWR SUPPLY
MOS PWR SUPPLY
CR PWR SUPPLY
Speedo
Wow thanks very much for the links.. i have the Cutie regulator Kit and dont have the sch..
regards
regards
megane79 said:someone has the diagram of the DC SERVANT MODULE?
Sorry DC SERVO MONO MODULE KIT DIY AUDIO
I bought a couple of the Audiotek speaker protection modules - the spec. says each module can handle up to 2 x 250W, suggesting stereo, but the schematic doesn't make speaker connection clear. No Left/Right or +/-, just two IN and two OUT.
I could assume +L and +R to and from board, with grounds straight from amp to speakers, but I would feel happier if someone with more knowledge could please confirm this before I kiss my tweeters goodbye... again.
Cheers
Rab
Cheers
Rab
Rab-
I have a speaker protect module like that- I forget if I got it from Audiotek or another Chinese seller. The grounds go direct to the speakers and the R,L go through the protect board. (I'm not sure that it protects much; more just a delayed turn-on??.) It gets AC-0-AC from the same transformer that feeds the amp.
If you have a pic, I can compare it to my unit.
BTW, I have a couple of sets of 'junk' thrift store speakers I use for testing stuff like this- I recommend it!
Cheers
John
Cheers
John
Rab-
Yup, same as the one I have. deals with the so-called + leads to the speakers only.
It seems to work fine, though mine hasn't made it off the 2x12 aka breadboard setup I use for testing ideas and eBay stuff.
Cheers
John
Cheers
John
Audiotek Speaker Protection
John-
Thanks for the confirmation - project tri-amp is back in motion!
Cheers
Rab
John-
Cheers
Rab
I haven't bought the kits, but did purchase FET's and
MOSFETs from Audiotek168.
I heard there have been a lot of fake Toshiba FETs
from China and was wondering if his stuff was any good?
or if I should just not bother and toss them?
I realise I am a newcomer here and that this is my first post, but I have a specific question about the AudioTek kits. I bought 2 of the input selector boards and one of the I/R Remote volume boards to build a studio monitor passive preamp. I've finished the build but have found the input selector boards don't operate when there is something plugged into the balanced input, otherwise everything seems to operate correctly. I'm fairly sure I've traced the fault to a mistake in the circuit schematic that seems to have been replicated on the PCB.
It appears to me that the negative phase of both the left and right hand balanced inputs are erroneously connected to ground rather than the respective L&R -ve phase busses (see attached schematic). I'm just wondering if anyone has built the same kit and encountered the same issue and could possibly confirm if I have got this right?
Do somebody here have any documentation, schematic etc. For the cutie miniregulator?
It seems that all the links for diyzone posted here are invalid.😱
In advance.
Thanks🙂
In advance.
Thanks🙂
Sorry to revive this old thread, i recently got some diyzone kits into possession from a generous person who donated them, they're whole kits but they got no schematic along with them. It would really be helpful if anyone could provide me with the same.
Kits in possession and schematics needed for :
1) LM4765 amplifier kit
2) Pooge2 power amplifier
3) Analog Buffer module
- General Interest
- Everything Else
- Audiotek kit assembly info
