Audiopipe AP 3000 1D
Here are some pics let me know if you need more
There are a total of 4 banks of fets there are 2 boards strapped together like 2 1500 boards strapped together unless I’m wrong .
On 1 of the boards there is 4 outputs on 1 side of the board and 4 outputs in the other side of the board same with the other board
1 set of drivers measures rail voltage the other side the drivers only measure 12 volts on all pins
OK. I've never heard of anyone treating this as one amp.
I'd suggest that you remove the rectifiers from the damaged half to troubleshoot the drive problems. After removing the rectifiers, you can more easily see the drive signals.
Do you have a scope?
Your unused sig line would be a good place to list all of the test equipment you have, including the power supply you use.
This amp uses STP65N06 as the power supply fets with 47 ohm gate resistors
I have mixed matched fets in it right now for testing since the originals were shorted .
Can I use the IRF3205’s in his amp as replacements ?
I’m working my way back to the drive problem so wanted to rebuild the power supply
Confirm that all 3 5v regulators in the output section have 5v out. Place the black probe on the tab of the regulator for each individual regulator.
If all are OK. Confirm that all rail caps are discharged. If they are discharged, you can check the drive for each bank of outputs with the ground of the scope on the source leg of the bank being tested.
