Audiopipe ACPLe-2004
The gate signal from the KA3525 Goes to R251 and R255. R255 is a 10K to ground. R251 feeds the gate signal to R235 and R239 22 ohm gate resistors to the power supply inverters. The same on the other side for R250. Maybe an educated guess based on the set up?
The pics.
I think the original resistor may have been something near 27 ohms (especially since one read near that).
You can't go too low or the zener circuit can't function (will likely never actually do anything, anyway). If you go too high, the FETs will run hot due to poor gate drive.
Confirm that the FETs run cool at idle.
If you want to experiment, you could install higher value resistors in those locations to see where the FETs begin to run hot.
