Hi Guys,
I just purchased some Audiomaster speakers (they were advertised as MLS1), but I am unsure as to what model they are, ie Audiomaster MLS1 or MLS2.
I have searched the web, but not much info on these.
I have included some pictures and would be really grateful if some can identify them please.
Many thanks
Many thanks
Nobody responded? Wait a little more...
(One thing moderators should do is to move the fullrange threads to multiway if the object doesn't fit in the category, but first the mod should explain
why a 2-3-4-5 way speaker is not a full-range one even if the bandwidth Vs power exceeds the limitation of a wideband etc etc etc. )
One thing for sure, multi way speakers have the crossover; many threads talk about substituting parts of it, many call it upgrading, most say that the electrolityc caps must be substituted. I see many el-caps in that board >>put fresh ones!
https://audionostalgia.co.uk/audiomaster-mls1-review/
by the looks of the drivers it seems that you have msl2
It's MLS2.
You have to check the HD 20B25H (WOOFER) ,you may need to replace the rubber rings, so you can have all the X-MAX of the driver.
Change all capacitors except the 0.33 one with the same quality ones
