audiolab 8000A ?
hi just got my hands on a audiolab 8000A it has a B in the serial number and the pcb number 27400.73 anyone know what year & version this amp is its very clean inside and out . i am running a pair of b&w CDM1 NT's speakers and the source is a cambridge audio 840c upsampling 24 bit cd player just wondering if i should change the cd or speakers ? or leave as it is . also the power caps is it wise to replace them with 15000uf caps and change the bridge rectifier with 4 single high current fast recovery diodes. what other caps are a whorthwile upgrade i dont use the phono stage.
The 8000A was fundamentally a DC coupled amp so if it's working I would just be happy with it. They were built around the mid 80's.
I do have the full 8000A Service Manual if anyone want it please PM me. It's a HUGE scanned book. Please ask Page by Page as most ISPs will block the entire scan.
8000a
hi i have a audiolab 8000a the mains transformer had blown the bridge rectifier had burned out and fuse blown . i have replaced the transformer and bridge rectifier and put a 100w light bulb in place of the fuse when i switch on the bulb glows then a few seconds later goes out . i have checked all four output 2x 2SC2922 & 2X 2SA1216 and driver transistors 2SA1668 & 2SC4382 out of circuit and all test ok any help please .😡
