Good idea, cumbb, having space.
But, in my view, having vertical space enough, the best solution is to put the amplifier over one of that special fan frames used to put laptops on.
That way, all the bottom of the amplifier will receive fresh air and the cheminee heatsink window ( if it is a 8000a) willl also have a generous air current flow. Just put the adjustable frame in the horizontal position... In general, that frames have 2x 120 mm fans, very silent... Works with any amplifier...
BTW, What's your actual amplifier?
Regards.
GA
Regards.
GA
At moment I do listen with a PA-940:
https://www.diyaudio.com/community/...y-stage-audio-jb-systems.416921/#post-7777393
A NAD 302:
https://www.diyaudio.com/community/threads/modifying-a-nad-amp.416991/page-2#post-7778295
Hiraga Le Monstre:
https://www.diyaudio.com/community/threads/hiraga-le-monstre.5462/page-48#post-7776444
And an outstanding little 2 Watt SE-follower;-)
A NAD 302:
Hiraga Le Monstre:
And what scientific conclusions do your listening comparisons lead you to?At moment I do listen with a PA-940:
A NAD 302:
Hiraga Le Monstre:
asks hbtaudio
