Audio Y Splitter Not Splitting Signal Properly
Hi all,
I have a setup where I take a stereo audio track created in Matlab (L track contains signal, R track contains noise) and present it out through the audio jack on my computer using a 1->2 RCA cable. This RCA cable should split the digital stereo track into 2 separate analog mono tracks for further processing. When I silence one of the analog cables (by unplugging either the L or R) in an attempt to either completely remove the signal or the noise, what I find is I'm left with a track that contains both signal and noise. If I unplug the L track, the remaining track tends to have louder noise than signal, whereas if I unplug the R track, the remaining track has a louder signal than noise. This suggests to me that the signal is somehow being premixed before splitting the stereo track into 2 analog mono tracks. I'm fairly certain the problem isn't the 1->2 RCA cable because I've tried using a simple 3.5mm headphone splitter instead and it does the same thing. I am working on Windows 7 with a Creative SB X-Fi sound card with the following details:
Driver Provider: Creative
Driver Date: 7/7/2010
Driver Version: 6.0.1.1348
Driver Signer: Microsoft Windows Hardware Compatibility Publisher
I would really appreciate any ideas for why the signal is behaving this way.
Jeff
...present it out through the audio jack on my computer using a 1->2 RCA cable. This RCA cable should split the digital stereo track into 2 separate analog mono tracks for further processing.
I would expect a 1->2 RCA cable to behave pretty much as you describe.
A stereo male to 2x stereo female, or stereo male to L and R female?
If you're fairly certain the signal isn't being summed by the cables, that leaves the computer itself as culprit.
