For Sale Audio transformers
Things you have for sale.
Hello, I have a bunch of audio transformers for sale:
Here is a high quality Audio output transformer for 1:2 line level applications
Genuine & original part dates from the 70's, pulled from an old mixing console
This transformer is of high quality with PCB pins intended for demanding line output applications
Plenty iron in the core and heavy copper windings so should be good for about +20dBm
~300 ohm primary and ~600 ohm secondary windings so can used as step-up or step-down
Approximately 44mm x 30mm and 35mm high excluding pins
USD18 plus postage
Cheers, Ralph
