Audio Transformer Spice Model
I need to create this transformer, which I have attached, for my circuit. However, this transformer is not in multisim, which I am brand new to.
I have been trying to use this audio transformer model I found:
.SUBCKT ts_audio_ideal 1 2 3 4 5
* EWB Version 4 - Transformer Model
* n= 2 Le= 1e-006 Lm= 0.001 Rp= 1e-006 Rs= 1e-006
Rp 1 6 1e-006ohm
Rs1 10 3 1e-006ohm
Rs2 11 5 5e-007ohm
Le 6 7 1e-006H
Lm 7 2 0.001H
E1 9 8 7 2 0.25
E2 8 4 7 2 0.25
V1 9 10 DC 0V
V2 8 11 DC 0V
F1 7 2 V1 0.5
F2 7 2 V2 0.5
.ENDS
However, this is only referring to having 5 pins. One primary and one tapped secondary. Since I have a transformer that has four primary and two primary which are tapped, how would I go about changing this model. I was thinking that it could be represented by 4P4S. Also how would I go about changing the turns.
Thanks so much!
I have tried just using a 4P4S model and then putting in the number of turns and resistance (which are all incredibly low) and the transformer keeps burning up all the resistors. This transformer is supposed to be a step-up and is placed at the end of an amplifier circuit. Please help!
You can only specify the winding ratio in-directly by providing the inductances of the windings, you will need the following parameters to build the model:
Primary end-to-end inductance, assuming it is center tapped, then the mid-point would be half of the inductance, ditto for the secondary, you need to specify the end-to-end inductance, and define where the tap appear on the winding, again in inductance value. The primary and secondary winding resistances should also be included for improved accuracy, if you have those figures, put them in, otherwise, use some generic values such as 250R for the primary and 1R for the secondary.
If you can provide those figures, we can help you to come up with an usable model. Or if you have the model number for the transformer, there might already be a model available, you never know...
