Hello im currently renovating three quad esl 57 one of the audio transformer is broken " self inflicted" haven´t found any spec on the transformer. would like to get replasment for it.
Four choices:
- replace with "old stock"/used original unit. (ebay, etc...)
- replace all three with new xfmrs of suitable spec
- buy three "new" xfmrs from the German (iirc) company that is now making them. (or other supplier like that)
- reverse engineer the bad xfmr, and wind ur own (or have it wound for you)
Determining the turns ratio and freq resp, etc (the xfmr specs) isn't that difficult to do using one of the "good ones."
_-_-bear
_-_-bear
Hi nobody,
you can ask them, they have made all transformers for QUAD:
Sowter Transformer Ipswich England
http://www.sowter.co.uk/electrostatic-loudspeaker.php
they are very friendly.
Good luck!
Frank
Good luck!
Frank
