If I have a step-up audio transformer with two independent primaries and two independent secondaries, can I connect the input to one primary and one secondary, and connect the output to one secondary and one primary, and thereby get a 1:1 ratio?
Any sneaky pitfalls?
Why make it so complex? Just use the primaries or the secondaries. Leave the other pair open.
Oh yeah. D'oh!
Hmm... Would I get better signal level using all the coils, though?
Edit: oops -- meant SNR, not level as such. Need more coffee... No of course I wouldn't would I, I'd get more copper loss due to increased winding resistance. Primary inductance would be increased so the low-end response would be extended some, but otherwise there'd be no improvement in using more coil, would there.
